Full Version: Hello from France
Hi all - I have just had a new driveway gate installed and have very little confidence in the local company who did the install of the DEA Geko electric motors (for various reasons).
So I'm here to try and get some understanding on the subject. I suspect I will need a lot of knowledge on this topic in the years ahead. Hopefully I'm not going to regret the upgrade.
Already the gates seem to have lost the plot as soon as the weather hit zero degrees C. And the slave motor does not have the earth wire connected. And the encoder connections are not being used which I thought was the point of using the Geko motors for a two-leaf swing gate? Anyway, I've clearly much to learn. Thx in advance.
(27-12-2021, 08:10 PM)robograben Wrote: [ -> ]Hi all - I have just had a new driveway gate installed and have very little confidence in the local company who did the install of the DEA Geko electric motors (for various reasons).
I would recommend getting another company out to come and see your gate setup, as if you have never dealt with electric gates / electrics before, it can be quite complex and sometimes dangerous.
The earth should be connected, so should encoders. The system should be booked in for a service from a reputable company in your local area.
-Jamie
