13-12-2021, 09:35 PM
Hi all, sorry for the long post.
After the recent storms, next doors fence being blown over caused some of the wires going into the control box to be pulled out. That is the connector blocks pulled out of the motherboard or bent down. I reinserted the blocks. No issues with the gate leaves being blown open or any other issue with wires, photcells, safety bar or pedestrian access switch.
When I have reconnected the blocks I attempted to run a cycle...Nothing much happened. The flashing light started, leaf 1.attempted to open, got about 6 inches and stopped. Same issue with any cycle, pedestrian access or remote fob.
I have attempted to reset the motors by running the quick start menu and resetting the limit switches. When I attempt to set motor 1 open limit by pressing the button on the motherboard, the gate opens 6 inches then stops, I have to release the button and press again. Same thing, 6 inches then stops. Repeat until the correct opening distance. When I press ok to set limit, ER SL comes up on screen. Now I must say the screen flashes something that may be another error but jumps to ER SL. I can't figure out what it is as it is too fast.
I have tried swapping the power to the opposite motor but the same thing happens.
ANY help would be appreciated. Starting to lose the will to live
Craig
Craig
