Full Version: Proteco Leader N1 problem
I have a Proteco Leader TI swing gate where motor was broken. After replacement, motor works for only a few seconds and then stops. Each time a start command is given, the same happens: motor runs for a few seconds and stops again. Fault notification on control board = N1. I have switched both swing gate motors to check whether it's motor related, but the problem remains: after switching, the other motor runs a few seconds and stops. Capacitor has been replaced as well; all wiring double checked since N1 is related to communication error between motor and control board??
Does anyone have suggestions?
