Full Version: But Rigel 5 and Deane a15 cells
Hi there
I am having a nightmare with the above. I have the gate, fobs and keypads working fine. When I try to connect the cells they don’t work. I have been through all the combinations listed in the manual with no joy. Can anyone please give me a definitive wiring description and advise as to what I need to set the control board to. I have 2 pairs of the cells in the system. Thank you in advance.
What is the desired configuration of your photocells?
Would you like them to work close only, open and close or open only?
Thanks for the reply
I would like them to work open and close, with stopping and then continuing without full reverse.
If I connect the front cells with no test in logik menu they work. Same goes for the rears. If I connect both then neither work.
