19-11-2020, 03:44 PM
Completely ‘new-build’ gate pillars, intercom/keypad, automatic gates and CCTV camera planned for an existing tarmac driveway. Installation advice sought.
Innocent newbie here. Please be kind. A bit of a long post - but hopefully removes the necessity for any obvious questions.
Two pillars, two gates. Light use planned. (Opened and closed - at the most - three/four times a day.)
The two brick/stone pillars will each be built around a steel post, each post receiving a 1.75m-wide (2m high) wrought iron gate.
Built into one of the pillars will be an ‘intercom’ panel; because this panel will face the entrance lane I’d like the solution to incorporate/integrate a CCTV camera which would be positioned to view approaching vehicles. (As opposed to a camera which - as I understand it from the photos I’ve seen - would show little more than the face of the caller.)
We’ll be cutting a trench across the width of the slightly-sloping driveway (not enough of a slope to cause an operational problem) to accommodate the electric supply and take away the surface water. The gates’ (expected) underground operating system therefore won’t be challenged by a water problem.
Preliminary discussion (with the probable gate fabricator) have resulted in me hearing the manufacturer ‘BFT’, and their product the ELI 250, being mentioned, although the gate fabricator sub-contracts the ‘automation’ installation to a preferred specialist associate.
As in ignorance I stumble forward, if anyone can offer any purposeful advice on what I should (or shouldn’t!) do I’d be extremely grateful.
TIA.
TIA.
