Full Version: Mag-lock not activating after close
Hi all,
I've got a Toona 4 system with MC284H control box.
I had to re-mount the static end of the actuators and so decided to run another automatic calibration routine to detect the end-stop positions...I then manually set the leaf-overlap and open positions according to the manual.
Previously, all worked well, and a magnetic lock activated after close to lock the leaves in position.
After running the calibration routine again, the mag-lock no longer activates after close.
I checked that the output is set to magnetic lock (and not courtesy light) and confirmed that it is indeed set to magnetic lock function.
Do I somewhere have to tell the control board to activate the magnetic lock? I can't find any reference to this in the manual.
Thanks, Ben
