Hi I have double gates operated by Frog A motors and a ZA 4 board , is it possible to change which gate closes first at present the left one closes first but I would like the right one to close first
Baza
Got this info from Came
You would need to swap the wires over with each other on the board so you would need to switch U and V into X and Y ,then X and Y into U and V
The logic on all of our boards is that motor 2 (X and Y) will open first and close last.
Away at the moment will try when I get back
