Full Version: Daitem SC100AU 1 controller 2 access points?
I have added another handset to my existing arrangement of 1 controller and 2 handsets. It has radio linked ok except - the 2 existing handsets are linked to Access 1 [which you would expect], the new one is linked to access 2[?] Why this happened I do not know. With the new handset after operating the gate open command nothing happens [it says Access 1] I can then select Access 2 and it will then open the gate. Pressing the gate command again does not do anything. I have to press the cancel button and operate asĀ  above.
Does any body know why this has happened?
I cannot find how to set Access 2 as default on the new handset?
Also the outside temperature is not shown on the new handset.
Any feedback would be appreciated.
