Full Version: SEA SWING 2DG gate won't stop tryin to close
I have installed SEA SWING 2DG gates system.  I'm trying to set it up correctly.  The first gate to close in the test sequence is Gate 2. It closes against the stops but won't stop trying to close. Everything stops there. I have to disconnect the mains supply.  Limit switches are not installed. Any ideas?
