Full Version: Nice a60 opening issue
Hi guys,
I have an issue that appeared 1 month after installation:
If i leave the gates closed for >1hour, the first opening command makes the flash go but no gate open. If i press again, the flash stops. If i press again, the gates open.... at this moment, the close and open will work any time.
If another 1h passes with mo action to the gates, the peoblem repeats.
Did you have this kind of issues?
can you show dip switch setting
