Full Version: Hi All BFT ALTAIR-P gates not closing
I installed these double gates some years ago.
Recently the customer had a power failure.
The gates stopped working so I reset the control panel.
Everything worked fine as I tested the gates by opening and closing.
Then the gates refused to close.
When I pressed the remote button both gates continued in the opening mode.
I am aware that the relays on this panel can give problems but would like to hear your thoughts.
The control panel is BFT ALTAIR-P
The motors are 240v and if I reverse the wiring the gates close but will not open
Sad
Michael
