Full Version: Re: Error 30
Wondered if you could help?  I have an automatic gate (DEIMOS BT 500kg) which is having problems opening/closing.  It's coming up with Error 30 on the electronic display.  Any ideas what the problem could be as I can't find this fault code in the instruction manual.
Thanks.
can you unlock gate to manual opening, just for checking how easy it can be close by hand ?
The gate will open and close fully in the test mode but when using the remote control, the gate will not always open fully and Error 30 is displayed. You have to go through the test routine to get the gate to close properly again.
Regards, Tony
