Full Version: AES DECT GSM Intercom landline dial programming
Hi guys
Recently I attended job where GSM intercom stopped dialling programmed numbers. I reset it via text to default settings then re-programmed and everything works fine except dialling landline number. When I request pre-programmed numbers it displays landline is accepted but it wont dial the landline cunt. Has anyone dealt with Dect GSM intercom before? Do you know the sequence landline needs to be programmed with? I must say it was dialing the landline before the fault. I will appreciate your help guys!
Cheerio
