Opened my gates and they went past the normal open limit setting. I now can't seem to reset the open/close limits on my gates - i go through the instructions setting open limit, press button and set close limit press button again but the open limit led starts flashing again. I've tried this several times and on each occassion the open limit led starts flashing again after setting the close limit... anyone know what the problem could be?
23mandl Wrote:Opened my gates and they went past the normal open limit setting. I now can't seem to reset the open/close limits on my gates - i go through the instructions setting open limit, press button and set close limit press button again but the open limit led starts flashing again. I've tried this several times and on each occassion the open limit led starts flashing again after setting the close limit... anyone know what the problem could be?
Hi, your problem could be that the gates aren't opening enough, the 24V arms have to use aleast 75% of the travel to set the limits. so try opening them further.
Hope this helps.
Atttached is a copy of the CB24 easy set-up guide which may help you.
