HAve a DEIMOS ULTRA BT A600. Gate wont open fully.
Error 35 & 37 popping up - cant find out what it is.
Also a photocell has been hit recently ( can here relay working and gate working as expected when the cell is covered)
Any advice welcome!
(12-11-2017, 05:37 PM)razer raz Wrote: [ -> ]Hi,
Any advice welcome!
are you sure that was error 35/37 or Er 3H ?
did you try to open the gates manualy ?
Please see below the error codes.
Error code 35 - Opening obstacle motor 1
Error code 37 - Slowdown opening obstacle detection motor 1
I would check that there is nothing which could be causing an obstacle and check that the gate moves freely without any resistance spots, hope this helps.
(14-11-2017, 10:32 AM)TimK Wrote: [ -> ]Hi,
Thanks for the codes
Ill have a look to see if anything is causing resistance ( this does corroborate with the display showing a higher load on the motor than the other leafs motor - which isn't presenting any error codes either)
All sorted gents.
Found debris underneath the guide rail, stopping the guide wheels passing by.
Once removed, gate runs smoothly!
Cheers!
