Hi there,
I found water inside the my proteco automation central case.
One fuse have blown. I've changed it but now show me the following error:
On stand by it only shows "_ ", and when cycling throuh the button A (the only button that does anything) it is showing
the following.
Q60 error video
Ty in advance for an help!
(02-11-2017, 08:25 PM)Jonas Pistolas Wrote: [ -> ]Hi there,
the following.
Q60 error video
You should at the begining take the central to the house and dry it .
which fuse blow up ? high voltage or low
The 5A fuse was the one that had blow up.
I already dried everything very well, but with no sucess.. ?
(03-11-2017, 05:13 AM)Jonas Pistolas Wrote: [ -> ]The 5A fuse was the one that had blow up.
http://manuals.easygates.co.uk/PDF/misc/mygate.pdf
you should check all accessories photo,receiver etc ...... with manual you can try to programing once again ..
Thank you for the manual.. i already got it, and none of the central error messages are described on the manual. I'm not able to do any programming, as a reset.
I already disconnected everything, and nothing changes...
I was wondering if there is a way to force the central to a reset...
Bests,
(03-11-2017, 07:58 AM)Automatic-TC Wrote: [ -> ] (03-11-2017, 05:13 AM)Jonas Pistolas Wrote: [ -> ]The 5A fuse was the one that had blow up.
