Full Version: LED on control board is off
Hoping someone can help. I've replaced and installed a new set of photocells on my BFT Deimos bt gate.
Then turn on the power, but it doesn't work, as the LED display on the control board is off. The LED display was working before I've installed a new set of photocells.
I've checked the main fuse and power wire connections with a multimeter that there is no open circuit.
Any suggestions on how to fix this LED fault?
Thank you in advance for any help.
Arthur
(07-07-2017, 02:44 PM)Arthur_k99 Wrote: [ -> ]Hi,
Arthur
Hi Arthur, I wonder if you had any luck with this? We have exactly the same problem! Thanks so much for any advice you can offer
You may need to check the integrity of the cabling. Either by running new fly leads cabled directly to the photocells from control panel to the photocells for testing purposes only and checking if this cures the problem.
