03-07-2017, 11:25 PM
Hoping for some help. We came back from holiday... The gate opened and then it wouldn't close. It displays Phot so I assumed it to be a photocell issue, which made sense as I wasn't hearing the usual relay click sound when something broke the beam. But... On removing the photocells and connecting them to a proper power supply they appear to work fine. The relays click happily and the output voltage from pin 5 on the Rx circuit changes as you'd expect. You can see the IR output on a mobile phone camera when connected to a separate power supply.
So, I started measuring voltage going to the photocells. There's just 3.7V going to the Tx photocell and 3.3V going to the Rx end. No happy relay clicking either, even when I hold tx and Rx ends next to each other with some extension wires.
Any ideas? Where do I go from here. Hopefully I've measured the right bits!
Hatbat
Forgot to say Bft 130 photocells.
Hatbat
