Hi! Have just moved to a new property with an electric gate - the gate key doesn't work and I'm trying to figure out how/what I can replace it with! Any help gratefully accepted
did you check battery ?
are you sure the gate are powered up ?
regards
Hi! Thanks for your response.
I'm not sure what the frequency is - is there a way to find out? Also I don't have a working gate key - is it possible to use a cloning key if you don't have any that currently work?
Yes have changed the battery and that hasn't helped. And the gates must work since the bin men get in to empty the bins!
(28-05-2017, 09:36 PM)cjones Wrote: [ -> ]Hi! Thanks for your response.
hi . spend 15-25 pounds for new receiver and transmitter thats my advice for your problem .
to check frequency you should have frequency scanner
