We've moved into a house with mhouse gates and a ds1 keypad. I understand that you need a puk code on the front of the manual to reset the pin. We don't have the manual or the pin. Is there any way to get the puk or override everything?
(17-03-2017, 07:37 PM)ramseygate Wrote: [ -> ]We've moved into a house with mhouse gates and a ds1 keypad. I understand that you need a puk code on the front of the manual to reset the pin. We don't have the manual or the pin. Is there any way to get the puk or override everything?
You will require the code to reset the pin, otherwise you can contact the manufacturer to have it it reset. You may require sending them the keypad & there may also be a charge. Nice UK Automation are the manufacturers.
