Full Version: BFT Sub R motor wiring diagram
Hi, does anyone have a wiring diagram for the Sub R?
I have a pair of motors I wish to bench test before installing and need to know what function each wire has.
I have wires coloured brown, black, green together with green and yellow earth.
I am guessing we have line, neutral and a second line for reverse but just want to check before testing.
On the same subject - is there a standard / generally accepted bench test for these motors?
Bit of further background.... motors concerned are dated 2004 and I am replacing them but I want to test both to see if either are worth keeping as a replacement motor as I am replacing with the same model. I just want to know whether to keep or discard.
Thanks!
You can find all the manuals you require on our manuals page.
http://manuals.easygates.co.uk/bft-sub/
hope this helps.
