Does anyone have any tricks on fitting rubber safe edge to backing plate. I know soapy water helps. I recently used 45mm edge and had real difficulty in fitting. 65mm is easier to fit but some tips would be good.
Hello
They say soapy water does help, but i always used liquid on it, as it made the edge alot more slippery, also make sure the edges are not cold when your fitting them as it makes it more difficult, try keep them in a warm environment until there ready to fit.
(22-11-2014, 10:12 PM)automatedgates Wrote: [ -> ]Does anyone have any tricks on fitting rubber safe edge to backing plate. I know soapy water helps. I recently used 45mm edge and had real difficulty in fitting. 65mm is easier to fit but some tips would be good.
