Have purchased two new remote control fobs neither will work. Have followed the cloning instructions several times without success. The fobs light up as per the instructions but do not work.
You may need to program this directly into the receiver if you cannot learn it from your original remote. You will need to go down to the gate operators control panel and open the lid. In there you should see the receiver which is grey in colour and has an oval programming button with an LED next to it. In order to program you remote, press the programming button on the receiver once briefly and release. You should see the LED flashing once a second. Press and hold down the button on the remote fob you wish to use. Keep this held down until you see 3 prolonged flashes on the receiver. This indicates a successful learn of your remote fob. Leave the receiver to come out of its learn mode (around 10 seconds), and test your remote.
We have set up a programming video of how to do this on the below link:
https://www.youtube.com/watch?v=bWGushvwY2U
Kindest regards,
Dave Blake
(15-01-2014, 12:28 PM)SPELLACEY Wrote: [ -> ]Have purchased two new remote control fobs neither will work. Have followed the cloning instructions several times without success. The fobs light up as per the instructions but do not work.
