inder
01-03-2009, 07:36 PM
I have installed the easygate under ground system for double gate with CB11 control board . The close , open photo sensors are connected to the correct pins with correct polarities . Some how the close sensers do not work .if I swope the two ie with pins 17 and 18 only pin 18 works . The voltage on pins 17 is 24v ac/dc on pin 16 is 15volts ac/dc pin 19 is 24volts ac/dc . This is a new instalation can some one help on this .The sensors are all ok . The setup procedure has been done for the photo sensors .
