Hi i'm having problems wiring my new Rigel 5, i use to have the Altair -P but it broke down, i also have the BFT Igea motors which worked well will my old system, but now with the Rigel 5 i cant seem to get the wiring right. I have put the earth into from motor 1 into 5 and blue into 4 and brown into 6, and the same for motor 2 but they open but not close, if i change them over they close but do not open. Has anyone any ideas please.
(07-10-2012, 06:14 PM)rapley Wrote: [ -> ]Hi i'm having problems wiring my new Rigel 5, i use to have the Altair -P but it broke down, i also have the BFT Igea motors which worked well will my old system, but now with the Rigel 5 i cant seem to get the wiring right. I have put the earth into from motor 1 into 5 and blue into 4 and brown into 6, and the same for motor 2 but they open but not close, if i change them over they close but do not open. Has anyone any ideas please.
Did you ever resolve this problem? I have a similar problem - 2 new BFT motors (and capacitors) installed onto an existing Rigel 5 control board, one side is fine, the other only moves in one direction on both open & close cycles. That direction is reversed if cables reversed.
