Full Version: Excessive play in BFT sub motor
I have a BFT SUB motor that gives about 400mm of play at the edge of the gate when stopped, this is resulting in it not fully closing all of the time. I have tried lifting it and moving it around 1 tooth on the spiggot but then it does not open fully so guess it is positioned correctly. Any ideas??
Thanks,
Steve.
I would sugest that if you have this much play in the motor then the seals in the hydraulic jack unit have gone.
(04-08-2012, 10:32 AM)BarkerandGeary Wrote: [ -> ]I would sugest that if you have this much play in the motor then the seals in the hydraulic jack unit have gone.
Thanks, does that mean a new motor?
