oldsparky
19-11-2008, 07:24 PM
Hi All.
Im in the process of tackiling my 1st install of automatic gates, im an electrician and have been asked over the years about installing gates, but i always walked away leaving it to the professionals. But now im feeling brave and have taken on my 1st job, with another 3 in the pipeline. Ive have installed all as according to instructions, but im having a problem with the photocells, the LEDs on the cells are flashing, 1st they werent on and i discovered this was a polarity problem and fixed, now they are flashing, this according to instructions indicates that the photocell disables the control board, i have my 2 cells connected into terminals 24 & 22, i have tried resetting several times but cant get them to remain constant. i have the gates set up and they are opening and closing fine with the key fob,but nothing happens when i cover the photocells either when gates or closing or opening, both cells are mounted at same height and directly opposite each other on piers.
Would appreciate any help on solving this problem.
Thanks.
Paul.
PS could you recommend a good coded/audio intercom to work in con junction with the CB11.
Thanks.
Paul.
