I have been getting the diagnostic error "RPM Reserval" all the time and i do not know how to rectify this problem. The gate will not close or open properly. I have tried resetting the limits many times and the gates will bounce back after it has been opend or closed.
Does the setup allow you to set the limits by holding the direction buttons or does it move a few inches then stop during the limit setup ? If it does then RPM sensor is gone in the motor most likely due to wires being shorted. If Not then most likely brackets are incorrect and arm has strained the gears inside causing it to fight against itself.
(16-05-2011, 03:53 PM)Mark Wrote: [ -> ]Does the setup allow you to set the limits by holding the direction buttons or does it move a few inches then stop during the limit setup ? If it does then RPM sensor is gone in the motor most likely due to wires being shorted. If Not then most likely brackets are incorrect and arm has strained the gears inside causing it to fight against itself.
The setup allow me to set the limits by holding the direction buttons with no problem and the limits are set propoerly. However, after saving, either on closing or opening the gate will not stop and bounce back and give the RPM reversal error. Sometimes after trying a few times, the limits will not be set and i have to disconnect the system for a good number of hours and try it again, then the limit will be set but the gate will not work properly. Please advise what else i can do.
