Full Version: bft lux2b
I've refilled my hydraulic ram with idrolux oil after a repair. But now when my actuator isn't used for some time there is no movement. The motor is running. If I turn the force adjustement screws a bit then the actuator moves again, but after a while it doesn't move anymore.
Is there something I've forgotten?
Problem is solved, the vent hole was blocked by something.
Problem returns.
Now I know the bleed hole isn't blocked because oil comes out. But when the actuator isn't used for about an hour it doesn't move.
Any ideas?
