i can only appolagise i have a Libra control panel. when i looked at all the pictures thats the one it looked like most :-( sorry. just went out and checked. mine has been installed in a none BFT surround and has been cut and shut a bit.
thanks
neil
Now all is clear
take it doesn't make any difference to what i need to do ?
thanks
neil
while i have got the ram apart is there any greasing etc i should do ?
thanks
neil
You can put some grease on the manual release mechanism, clean worm-drive and put some grease on it. Check all moving parts especially plastic or brass bushes which are moving on the worm-drive. But to be honest as far as worm-drive is clean and greasy all will be fine.
resoldered the joints on the small board that sits inside the ram that the limiter switches are wire to.put it allback together and the gates worked fine.
then i adjusted a limiter switch position on the other gate and it all started going wrong !! gate would only move about 2" then stop, after a few presses of the fob button i now get nothing !!!
i noticed on the control panel when gates were only moving a little i was getting a code ANP or AMP ?
any suggestions as to what i have done as i was so pleased when the gates were working !!
Manual, page 13
In the case where an obstacle is found, the LIBRA panel stops the door and activates a reverse manoeuvre; at the same time the display shows the “AMP” message.
Monitoring: During the opening and closing phases, the display shows four digits separated by a dot, for example 35.40. The digits are constantly updated during the manoeuvre, and represent the maximum torque reached by motor 1 (35) and motor 2 (40). These values allow the torque setting to be corrected. If the maximum torque value reached during the manoeuvre gets sensibly close to the value set in the parameter menu, malfunctions may occur in the future following wear or slight door deformation. It is therefore advisable to check the maximum torque reached during some of the manoeuvres carried out in the course of installation, and if necessary set a value about 15-20 percent points higher in the parameter menu.
thanks yet again.
this AMP message came up a couple of times then it stopped, when i left it last night all you got was the message 'STRT' come up with nothing afterwards and the gates done absolutely nothing, no life in them at all !!
really frustrating after having them working for a while for it to go to nothing !!
anybody know where i can get a set of the limiter micro switches ?
