I have a daitem entry system comprising a D5131 handset, D5200 control box and D5821 panel with keypad. The batteries went on the handset so they were replaced with rechargeables. Since then although the handset has icons it does not connect and I cannot get a radio signal on it by going through the pairing instructions. We found the antenna to be damaged but have replaced that.
Any advice and any replaceables would be welcomed!!
Unfortunately this will probably be a handset fault, however the spare parts are no longer available for the D type analogue system. You now have to convert the complete intercom system (Call point, Receiver & Handset) to the new digital system which can be found in the link below.
http://www.easygates.co.uk/product_info....ductID=678
(22-12-2017, 09:39 AM)Sav Wrote: [ -> ]Hi,
Thank you - thought that may be the case! Hopefully someone will have a handset they may wish to sell as replacement of whole unit not an option at the moment!
