I have a set of Gibidi operated electric gates at my property and they are closing in the wrong sequence - the gate that should close first seems to be operating slower. This then obviously means they will not open correctly so they are stuck on manual at the moment! I would be very grateful if anybody could help me with what may be causing this!!
(25-03-2017, 09:37 PM)sgh123 Wrote: [ -> ]I have a set of Gibidi operated electric gates at my property and they are closing in the wrong sequence - the gate that should close first seems to be operating slower. This then obviously means they will not open correctly so they are stuck on manual at the moment! I would be very grateful if anybody could help me with what may be causing this!!
can we have more info , control board name ?
switch off the power
open them manually max you can
check if each wing gate opening with no resistance
switch on power and use handset to close
